Marieholm IF motor well
Plankit
Inlägg av Plankit »
Hello all, I would like to receive a photo or diagram of original IF MARIEHOLM 26 motor well.
Previous owner modified the motor Well and Needs work. Thanks for your time ⛵️
Re: Marieholm IF motor well
On this link you find a picture of the motor well.
https://www.google.se/imgres?imgurl=htt ... egUIARCYAQ
If the link does not work I suggest you search on Google with the words "if motorbrunn" That was how I found it.
"IF" is the most common name used in Swewden for the boat that in other parts of the world is called International Folkboat, and "motorbrunn" is of course Swedish for motor well.
The bow is to the left and the stern is to the right. The rigging screw is if I understand it correctly used for pressing the over of the opening downwards to keep it in place. But perhaps other members on the forum knows more.
I have a well on my boat, but it has been permanently closed (as I believe is done on many boats, since few if any use the motor well for a motor today as it is too small for today's motors. I instead use it for storing the anchor and the anchor cable.
