Sealing deck to hull!
Postat: 30 aug 2020 11:59
What do you use to seal the deck to hull on the outer lip?
I presume you cannot get leaks from this area when the boat is upright just from rain as the deck lips over the hull. Leaks I should think can only happen with the deck submerged in the water when sailing at an angle? Just trying to work out where my leaks are coming from!
Thanks Chris
Thanks Chris
