Sökningen fann 21 träffar
av Captain_frog
09 nov 2014 22:20
Kategori: Common
Tråd: Motor angle in well
Svar: 7
Visningar: 15676
Re: Motor angle in well
Hej! Here are some photos You can see at the back of the boot (she is now in Berlin) the control jet water running (right) an the exhaust fume (left). The control jet fitting is a garden hose fitting which has been widen to fit on the outlet (11 mm diameter) and is hold in place with a metal plate ...
av Captain_frog
03 nov 2014 20:55
Kategori: Common
Svar: 7
Visningar: 15676
The previous owner of my boot had 3 very good solutions. He fixed a tube under the control water jet outlet to eject the water at the rear of the boot He fixed two metal fittings on the 2 smal exhaust outlets in the upper part of the shaft (glued with some kind of metal cement) and fixed a double ...
av Captain_frog
01 nov 2014 21:39
Kategori: Common
Svar: 7
Visningar: 15676
Motor angle in well
Hello sailors Now my boot is out of water for the winter and looking at the motor (in well) it looks some kind of weird! The shaft has an angle of about 15 degrees against vertical (it looks as if the propeller wants to overhaul the motor). Is it normal? Should the shaft not be vertical in the water ...
av Captain_frog
29 sep 2014 19:30
Kategori: Common
Tråd: Don't step on my blue suede antifouling
Svar: 1
Visningar: 6301
Hello Sweden The IF boat I bought in Sweden has a "International Micron WQ" antifouling. This special type is not available in Germany. Here they only sell MICRON EXTRA EU or Micron WA or MICRON EXTRA or even Micron Extra 2 but no Micron WQ. My question is: what about compatibility? Can I put some ...
av Captain_frog
28 sep 2014 19:35
Kategori: Common
Tråd: IF boot motor in Winter
Svar: 7
Visningar: 16102
Re: IF boot motor in Winter
Thank you all for the tips
I think I will have to thake the boot out of the water this winter. All other solutions are more complicated and would mean a lot of work before and after sailing.
Anyway thank a lot for those useful answer.
Captain Frog
av Captain_frog
14 sep 2014 14:05
Kategori: Common
Svar: 7
Visningar: 16102
Hello Svensk båtägare! I'm the owner of an IF boot with an outboard motor in well (Mercury 9 HP). I leave in Berlin and I would like to leave my boat in water during the wintertime. I already ask many people and they all agree that the boot hull should not be a problem when the lac freezes, but n ...
